Driver side front window
Driver side front window won't go all the way up
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@cammyvonre52411 we will need to know your exact model year and if it is a two door coupe or a four door sedan. There are differences in the power window wiring. This is assuming that you are referring to power windows.
If this is just an issue of the window freely moving down and then back up just not going all the way up, then it is most likely a regulator assembly issue. To check the wiring and to work on the window regulator, use the Doors Manual Page 62 tells you how to test the power windows (just in case it is a motor issue) and Page 199 shows the removal/installation of the window regulator.
Once you have the trim off and can see the regulator, take a couple of pictures that show the regulator etc. and post those with your Question. That will allow us to see what you see. We can then try and help you to determine if you have to replace it or if it can be fixed.
Bu yanıt yardımcı oldu mu?
There could be a few issues:
1. Check your window switch in different positions if your window is rolling up or down slowly or has intermittent stops replace the switch
2. Check the window track it may need to be greased or have something in it blocking your window.
3. After those two check your window regulator and your window motor if either one has not enough power it will keep the window from rolling up.
If you need any kind of help with diagnoses let me know and I'll post step by step how to do each.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 42
Her zaman: 835
1 Yorum
Potentially a broken hoist mechanism for the car window. Refer to year and model relevant owner's guide to find if it is described there.
Markus Norstrøm tarafından Paylaş
