Ana içeriğe geç
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor. Released June 8, 2017.
How to change the headphone socket on this computer?
And is there a special series-no. for the new socket I need to be aware of when trying to find the replacement socket online or in a store.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
You can follow this guide to take it apart to have a look at the damage inside then follow the guide to add images to an existing question.
iMac Intel 21.5" Retina 4K Display 2017 Teardown
Adding images to an existing question
tarafından
Thanks Makus, the tearappart is only interested in the software. I need help to change the hardware part for headphones/mini jacks, sound out socket.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Your in luck! While a pain to replace as you need to remove the logic board to get to the inner case area where it’s glued with hot glue iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement (you’ll need a heat gun to soften the adhesive to get it off). Here’s the needed part 21.5” iMac Headphone Socket and Cable. I find you really need to fully clean off the old adhesive and after warming the case area and the part a fresh application of hot glue is the best way as it’s hard to mount the plate tightly to the case with the old glue present.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Tanja sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 144
