Ana içeriğe geç
12 Eylül 2012'de duyurulan, Apple iPhone'un altıncı sürümüyle ilgili onarım bilgileri, sorun giderme ipuçları ve kılavuzlar. Model: A1428, A1429
iPhone not turning on
Hey everyone, I have this old iPhone 5 I’d really like to get working again. Started with a battery replacement and I got some life, I could hear sound and Siri worked, however the screen wasn’t on. So I changed the screen. Still the same issue had sound, saw it come up on iTunes, and after a little bit I had no life. I know there are many possibilities but since I did have life, I’m wondering if the charging port just was fried. Before purchasing a replacement any thoughts on anything else I could try? Or anything I might be missing in terms of another fix? Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I'm not sure if I follow the possibility of a charging port being the issue. It sounds like the main potential problems are:
  1. The Screen
  2. Damage to the logic board during the battery replacement
The fact that the computer recognizes the phone indicates that the charging port works fine, and the fact that you can hear the sound coming from the device indicates that it is booting up.
I would try a replacement screen first. The LCD could have gone out or been damaged in some way. If that doesn't work I would assume there was damage done to the logic board during the battery swap, such as a blown backlight diode or blown backlight fuse. These repairs require microsoldering, but the components are pretty cheap.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Tharrett sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 211
