Ana içeriğe geç
Released in 2021, the Alienware m15 R6 (model P109F) is a high-performance gaming laptop featuring Intel processors and NVIDIA GeForce RTX 30-series graphics.
3 Soru Tümünü görüntüle
Video_tdr_failure on battery only
Hi have problem with my alienware, most of the times i try doing something without charger plug in the Video_tdr_failure BSOD pop up
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@whitestorm that error code usually refers to an issue with wither the GPU driver or a bad video card. Not sure how this relates to the disconnected power supply. That makes the GPU circuitry the prime suspect. Anyhow, try to update your drivers and let us know what is going with your Alienware after you do so,
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Yeah, that weird for me, i'm updated the drivers, try to change to studio version, trying change power mode, and still sometimes it just bsod only when i'm on battery
tarafından
@whitestorm makes me wonder if this is not going to be power issue on the video circuitry or possibly a Windows issue. This is tough to get a handle on since it appears to be only intermittently.
tarafından
@whitestorm
Has the cpu and/or gpu been overclocked at all?
Go to Task Manager → Startup and check how many programs are running in the background using up resources unnecessarily.
Some are necessary for correct operation but a lot aren't. Some are there just so that they will open up quicker if and when you decide to use them.
Try disabling the programs that you feel aren't necessary to be loaded at startup. To do this right click on the programs in Task Manager and select disable → disable, then restart the laptop in the normal manner and check. Disabling programs in Task Manager doesn't stop them from working, they may take a bit longer to open that's all.
If disabling a program in Startup causes problems simply enable it the same way as you disabled it.
To get to Task Manager in Win10/11 right click on the Taskbar.
Also just to eliminate the possibility of a bad battery, create a battery report to check the condition of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value shown in the report. For a good new battery they should nearly be the same value. You can work out the condition of the battery as a percentage by using the formula Full Charge Capacity value x 100 ÷ Design Capacity value.
tarafından
Yorum Ekle
Yanıtını ekle
Andrzej sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 89
