Ana içeriğe geç
The PSP E1000 is a handheld games console designed by Sony. Also known as the PSP Street, this budget-friendly version of the PlayStation Portable released in October 2011.
My psp battery has died/leaked. Is there any way I can save it?
My PSP is a E1004, and its almost 10 years old now. The battery has most likely leaked, because it has a few stains it didn't use to. Is there any way i can save it, make it work again?
I tried opening it but after the 4 back screws and 2 top screws i got scared of accidently breaking it due to excessive force.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
if the battery leaked: The only way to fix this, is to replace the battery and clean the motherboard with isopropyl alcohol. Till all the stains are gone and the motherboard is cleaned again. After this try again with a new battery and see if it works.
You probably need to remove the UMD door as well, here you access the battery (after removing the screw under the warranty sticker and removing the plastic cover). But be carefull as you can break it with excessive force.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
@manyeetit well,you do have to open it. Use a good screwdriver when trying to open it. Always use a new driver since an old one can "chew up" the screw heads. If that happens, you can usually drill them out. Just use a drill bit about 3/4 the diameter of the screwhead and drill slightly through the center of the screw. That will most likely break off the screw head. If it does not do that, use a slightly larger drill bit.
Once you split the case, you can remove the rest of the screws with a pair of pliers. Now comes the fun part. Time to disassemble your device and to clean everything with +90% isopropyl alcohol and a soft brush. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your PSP as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid, as well as corrosion particles, into areas that will cause trouble later on.
Once cleaned check for corrosion damaged like lifted traces, corroded via's as well as failed components. Post some good pictures of both sides of the circuit board with your question. That way we can see what you see and hopefully guide you further. Now, if everything looks good and you are sure about not shaving any corrosion issues (check the fuses as well) get a new battery and see what happens :-)
PSP E1000
Adding images to an existing question
iPhone Görseli
Kılavuz
Repairing iPhone Liquid Damage
Zorluk:
Zor
1 - 2 hours
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Puan 1
Yorum Ekle
Yanıtını ekle
ManYeetIt sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 45
Her zaman: 917
