Ana içeriğe geç
Çeşitli tamir aletleri için onarım bilgileri.
Tools for smartwatch repair
Hi i am looking for relevant tools to repair smartwatch with respect to hardware and software.
I am using amazfit gts 2 mini
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @shubh8030
ifixit has a range of pry and opening tools that should be able to open the watch.
Here's a video that may help you to open the watch
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
Thanks for sharing the video it will really help, I am also looking for software tools to fix its software
tarafından
@shubh8030
You may be out of luck as far as software is concerned as the manufacturer's only provides a user manual and EU conformity certificate on their support page for the watch and no software downloads.
You could always try contacting Amazfit on support@amazfit.com and ask them. It never hurts to ask ;-)
tarafından
Yeah I did it but they are asking for money to fix 😄
tarafından
@shubh8030
You never know, replacing the battery might fix the software.
When you have disconnected the battery either do not reconnect the replacement battery for a few hours and then connect and assemble etc and fully charge the battery before turning the watch on or if the Power On button is still connected to the motherboard, with the battery not connected, press and hold the button operated for 30 seconds.
This will drain any residual power from the board and hopefully might correct any software glitches.
Won't hurt to try as the watch is disassembled anyway.
tarafından
That’s good way to give a try thanks a lot will update you soon 👍
tarafından
Yorum Ekle
  1. An ability to open the device (iOpener)
  2. A razor (not one that you use to shave) (Buy one here)
  3. A spudger (any one works but here is ifixit's)
  4. Tweezers (pointed screwdrivers are important)
  5. Picks (a guitar pick works too)
  6. A screwdriver with a set of screw heads (ifixit's)
These tools are for apple watch repair, your's might be different but hopefully this is all you need
Tools for holding and manipulating small and delicate components. Blunt, pointed, and angled versions. Görseli
Ürün
Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive. Görseli
Ürün
iFixit Opening Picks (Set of 6)
$4.95
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries. Görseli
Ürün
iOpener
$24.95
A large curved razor blade Görseli
Ürün
Curved Razor Blade
$9.99
Plastic tools designed to get you in the tightest cracks, without damaging your treasured devices. Görseli
Ürün
iFixit Opening Tool
$5.95
With a polymer driver handle and 32 bits, iFixit's Moray Driver Kit offers maximum utility in a compact package. Keep on hand in a kitchen drawer, a car glovebox, or a toolbox. Görseli
Ürün
Moray Driver Kit
$19.95
Puan 1
1 Yorum:
Thanks for sharing 😄
tarafından
Yorum Ekle
Yanıtını ekle
Shubh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 41
Her zaman: 1,172
