Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
disc drive renesas question
has there been any way discovered to marry a new renesas to the ps4 so the disc drive will work? mine may be toast because a pin broke off when i removed it to swap it to a replacement daughter board. i hope it can be fixed because the motherboard works and just needs a hard drive
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
9 Yorum
@techlord let's see the damage. Post Some good pictures of what this all looks like, with your Question. Maybe we can all come up with some ideas. Adding images to an existing question
tarafından
@oldturkey03 ignore all the flux leftover
tarafından
@oldturkey03 it's the exposed pad where a chip leg should be that i don't know if i'm screwed or not
tarafından
@techlord could just be the flux etc. but it looks like plenty of solder bridges on your contacts. Consider cleaning it and check for solder bridges. Looks like there maybe a little edge left. Got some excellent soldering skills and good tools?
tarafından
I agree with oldturkey. Looks like some connections are bridged. Make sure none of them are bridged.
tarafından
4 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
I hate to say this, but no.
There is no official legit way to fix it when the disc drive PCB is broken. Only Sony can fix this for you as they can marry another PCB with the motherboard and match the codes.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
is there a pinout for the renesas so i can see if mine is toast or if i can salvage it
tarafından
I tried to searching it, but can’t find it.. I’ll try later searching for it again, sorry.
tarafından
another question, will a different daughter board at least allow me to install the firmware or am i going to get the same error it gives when it can't find the blu-ray drive
tarafından
Can you add a picture regarding the drives it's PCB? Then I'll search on that :).
2nd question answer: No. It will give you a different error which prohibit you to update the system. The disc drive PCB need to be intact before you can update the firmware unfortunate...
tarafından
Yorum Ekle
Yanıtını ekle
Cheap gamer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 207
