funky stuff going on with display
this macbook works fine hooked up to an external display, but it's built in is only backlit. The built in is the original built in display from another macbook of the exact same make and model. In the system info app i can tell that the computer recognizes the fact that the display is here and it is connected into the display, there isn't an error showing and i'm confused. I guess what I am wondering is why i can see everything totally fine on an external display, but i only have backlight on the built in, with no errors showing?? Thank you!
Update (04/16/24)
I would like to add that I’m using the exact macbook on an external display to write this.
Also - this exact built in screen when it was on its original computer before I put it on the one I'm on now, it had the same issue, I moved it over because I thought it was a software thing.
Update (04/16/24)
here is a picture of it
Bu iyi bir soru mu?
sorry the room is messy
jackypoo100 tarafından
@jack_likes_tech your room is fine, should see my shop:-) Anyhow, quick question. Why did you replace the original display?
oldturkey03 tarafından
because it was cracked and was all wrong colors and then I bumped it on something and the backlight turned off
