Ana içeriğe geç
The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Left JoyCon will not charge or connect to the switch
Hello,
my left JoyCon won't connect to the switch or charge on the switch or an external charger anymore.
Here's what I already tried:
  • My switch works with a different left joycon, so it's not the switch.
  • It worked in wireless mode until the battery died because I couldn't charge it anymore.
  • I tested every button in test mode, they all worked.
  • I triple checked the flat band connectors.
  • I cleaned the rail connectors with a toothbrush and isopropanol while turned off.
  • I exchanged the rail of the JoyCon.
Is there anything else to check? What would be the next step? Exchange the bord of the JoyCon?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
I think this in my originial post covers it: "My switch works with a different left joycon, so it's not the switch."
tarafından
A new board didn't fix it. Since by now also the battery is dead I can't tell if the new board works at all or if the problem is somewhere else.
Any ideas?
tarafından
Hi! So you tried a new motherboard, but now there is no sign of life at all? If this is the case, you may have received a faulty motherboard. Better return it and get a new board! Please also make sure that all cable are connected.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Wren!
So, you already tried to replace the Rail of the JoyCon it self, right?
Then I think the next step is to replace the battery, as the battery does not want to charge.
If this failed as well, we probably need to check the motherboard.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Yes, I already replaced the Rail of the JoyCon. Does the battery replacement make sense when it also didn't connect in handheld mode while the battery was still charged?
tarafından
Could still be battery related in weird circumstances... I would try it first. If the replacement battery does not work, return it and get a refund. Then it must be motherboard related.
tarafından
I switched the batteries between left and right JoyCon and the left one still doesn't connect but the right one charges. I'll order a new board then.
tarafından
If the Joy-Con is having the exact same issue on another Switch, then this is probably the only part left which can cause it. Please let us know if a new board fixed it! Thanks
tarafından
Yorum Ekle
Yanıtını ekle
Riverside Wren sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 116
