Ana içeriğe geç
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
SSD Won’t boot once installed only externally… HELP
SSD (Lexar SATA 6Gb) Won’t boot once installed Internally screen goes black then the prohibition sign appears but it will boot externally while the original HDD is installed anybody have a solution?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
It’s likely this SSD is a fixed SATA III (6.0 Gbps) drive not the needed SATA II (3.0 Gbps) this system requires. While there are Auto sense drives which will drop down it’s I/O speed to match the systems. I don’t believe that’s the case here. So why does it work externally? The SATA to USB case can force the speed as the standard was updated after this system was designed.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Kapp God sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 72
