Tcon board fuse (input voltage) reads 11.7
TV Brand - TCL model is 40S6500fs
I am attempting to figure out the issues on my TV. The backlight and sounds are working. I found that there are some test points to diagnose which i did and found the fuse on the TCon board is less than 12V ( Same reading on both side). So what should i do next?Uploaded images here. Thank you for your time and responses.
Update 05/14/2024
Update 05/15/2024
Bu iyi bir soru mu?
2 Yorum
Hi @manikanda30528
What is the make and model number of the TV?
Have you checked the 12V supply from the power board (or mainboard) to see what value it is?
It may be that 11.7V is what is being supplied so the voltage measured on the tcon board would be the expected voltage.
jayeff tarafından
Sorry for not providing the required information.After surfing through the internet, i assumed that standard operating voltage is supposed to be more than 12( Usually of 12 to 15). Will upload images in my later comments.
TV Brand - TCL model is 40S6500fs. Country - India.
Also let me add another detail regarding my problem. Initially TV ran into a trouble where it displayed two screen alternatively on a loop - Full white screen and a grey background with DSLR cam viewfinder overlay like structure at the center.
Then i removed the ribbon and other removable connections to clean( just removed the dust and dirt). After connecting back , i turned on the TV only to find display went grey dark( no display)
mani kanda tarafından
