Ana içeriğe geç
ThinkPad T450, 5. nesil Intel işlemcili, hafif ve sağlam bir 14 inç iş dizüstü bilgisayarıdır. Cihaz 2015 yılında piyasaya sürülmüştür.
Laptop does not charge. No light indicator
The laptop does not charge, the power botton and red dot on "Thinkpad" usually blinks I plugged the charger. But now it does not do that and the laptop does not turn on. I tried removing the battery, unplugged the charger then pressing the power button for 30 seconds and plugging back the charger but it is still the same. No blinking lights, No charge, laptop does not turn on
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @evonmaxilom
Use a DMM (digital multimeter) to check if there's 20V DC on the output plug of the charger. If you don't have a DMM then try using a another known working, compatible charger and check it works OK when charging the laptop.
If the charger is OK then here's the hardware maintenance manual for the laptop.
Go to p.81 to view the procedure to remove the DC-In cable. At this stage all you need to do is to unplug the cable from the motherboard and then use a DMM to check if there's 20V DC when measuring between the red and black wires on the cable plug, with the charger connected to the jack as per normal.
If there is no voltage detected then the jack is faulty and it will need to be replaced as it cannot be repaired. Search online for 00HN539 to find suppliers that suit you best.
If the correct voltage detected, then the schematics for the motherboard would be required to find out what's wrong.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Evon Maxilom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 914
