Stage-light effect occurs after a few minutes of running
I have a stage light issue with the 2018 MacBook Pro (A1989). It occurs after a few minutes of running (variable times) and whenever I adjust the screen to max brightness. I was mistaken in that it does occasionally appear at login. 'pmset displaysleepnow' fixes the issue only when the screen is not set to max brightness, yet it doesn't last very long (variable). It does seem dependent on how many tasks I am running. All display options are off. Have tried to reset vram but doesn't seem to have an effect. Any insight would be greatly appreciated!
Since this got moved to its own question I'll add that unlike the previous person with seemingly the same problem, whose Mac was in great condition, my Mac has taken a tumble a while ago, can't remember if the issues began then.
Bu iyi bir soru mu?
5 Yorum
@jeremy99686 let us know what exact model MBP you have. This question got converted from a comment to its own question. Also, this "occurs after a few minutes of running (variable times) and whenever I adjust the screen to max brightness" sounds like a backlight issue. Most likely a bad LED strip (or controller) that shuts down once it gets hot from the max power. Post an image of what your display shows with your Question. That way we can see what you see.
Adding images to an existing question
oldturkey03 tarafından
@oldturkey03 Thank you for your response, the heating issue does make a lot of sense, the longer I run my computer the more quickly this issue appears. Thank you!
Jeremy tarafından
@jeremy99686 It could be the backlight inside your LCD (BAD) or the power to your backlight strips (BETTER) let me see if I can find more info on the display adapter. It is also possible that this a Flexgate issue (REALLY BAD). Again, let me see first if I can dig up more info on your computer.
@oldturkey03 Wow I really appreciate it, I do have a multimeter so I could attempt your method but can't confidently say I wouldn't do more harm than good. It does work well enough for my uses so I don't want to take up too much of your time. A I see what you mean by the power to the backlight strips, so that would not require a new display? Also don't think it's a Flexgate issue as the problem never appears as a result of tilting the screen. cheers
Jeremy tarafından
@jeremy99686 I also had this problem with a 2009 model:
Stage light effect, external works fine which has now died completely.... might be of a similar issue.....
livfe tarafından
