Ana içeriğe geç
The Nissan Juke is a subcompact crossover SUV produced by the Japanese manufacturer Nissan since 2010.
18 Soru Tümünü görüntüle
My horn is not working
My horn is not working. It is not the fuse nor the horn relay how do I fix it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @ginnytaylor
Is the horn relay operating when you press the horn button i.e. can you hear it click - you may need two people to do this?
Remove the horn fuse and then remove the horn relay and short out pins 2 & 3 in the horn relay socket. Replace the fuse and check if the horns work. You don't have to press the horn button as they should work once the fuse is reinstalled
If they work OK that proves the wiring from the relay to the horns is OK.
If they don't work there's a wiring problem between the relay socket and the horns. Check that the wires are connected securely on both of the horns.
You will need a test lamp or a voltmeter to prove that the horn switch and the combination spiral switch (in the steering wheel) wiring circuit to the relay is OK.
Here's the wiring diagram for the horn circuit for 2011-2016 Juke models, that may help. (you didn't specify the year)
(click on image)
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Ginny Taylor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 202
