Logitech G533 Headphones doesnt work without USB cable
My headphones don't work without the USB cable.
After disassembling the headphones, I found that the red wire was disconnected.
That's why I re-soldered it.
After soldering, it will light up when I plug in the USB cable, but when I unplug it, it won't work again.
Bu iyi bir soru mu?
4 Yorum
@mnkquqlvamire0y we will need a bigger and focused images of your repair. Right now the image is 672x369 and can't be viewed by zooming it. Try again just with a bigger picture.
If works with USB but not without. IS that a correct statement? Why did you need to repair the original wiring? what happened to it?
oldturkey03 tarafından
@oldturkey03
ねこまろ tarafından
@mnkquqlvamire0y okay so your headset has issues with the wireless but functions in USB mode. Good. Now let's see if we can find a solution.
@oldturkey03 Thank you for your reply.
So what should I do next to check for repairs?
ねこまろ tarafından
