Ana içeriğe geç
This page includes repair guides and technical reviews of Huawei Mate 10 (released November 2017).
My charging port, not charging
Not charging when connected to charge.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@saviterah you are not giving us enough information. You need to consider letting us know if anything happened to your phone. It is important to know if it just stop charging and what have you checked and tried to fix it.
First you want to check your charger. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your phone draws any amperage from the charger.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. Measure the voltage on your battery connector with the charger plugged in. You should get around 4.2V If you don't get that voltage check your flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on it. Your phone has a separate charging board that could be faulty. Consider replacing that.
To replace the charging board, use something like this guide Huawei Mate 10 Pro Charging Port Replacement It is identical for your model. Replacement charging boards are readily available at many online places.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Savi Terah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 65
