Schematics for the PowerBook g3 lombard?
My powerbook g3 lombard won't turn on and I don't know why. The fan does not spin and the cpu doesn't get hot when I try to turn on the computer. I also tried replacing the 10v 100uf tantalum capacitors but it didn't make a difference. Not even the service manual helps.
Bu iyi bir soru mu?
@maxplayz what numbers are printed on the logic board?
oldturkey03 tarafından
Do you mean the logic board part number?
Max Playz tarafından
@maxplayz anything like 661-2174 etc or a 820-____ number You did check to make sure that your power supply is still working etc.? You have checked the power/charging board for any damage? Which capacitor did you change and why? Post some good pictures of your boards with your Question. That way we can see what you see. Adding images to an existing question
@oldturkey03 it's a fully working power supply and the capacitor I replaced was the 220uf 35v capacitor
@maxplayz how did you check that the power board is working? What voltages do you get on the board?
Post some pictures of your boards with your Question That way we can see what you see.
