Ana içeriğe geç
Buz otomatı, otomatik buz çözme sistemi ve yoğuşma önleyici rezistans anahtarına sahip bir alt donduruculu model olan GE Buzdolabı GFE27GMD ile ilgili onarım ve ilgili bilgileri bulun. Bu sayfa, GFE27GMD**** model numarası desenine uyan modeller için bilgileri kapsar.
Why does my fan keep stopping
Hello. I have a GE GFE28HMHDES french door refrigerator. The fresh food fan started making some noise and intermittently running. I replaced the fan and now it is quiet, but will stop running after a while. Unplugging the fan harness and plugging it back in will get it to run, but then it will eventually quit. I ran diagnostics and it received a 00 00 code, which means it failed with 0 RPMS. Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
GE issued a Customer Satisfaction program bulletin for this a few years back. I'm not sure if it is still in operation but GE was honoring free repairs for this. The part they are saying should be replaced is WR49X25197. However, depending on your serial number, the part won't work after a replacement and requires a software update to function properly. If your serial number range is HD - FF (May 2014 - Mar 2015) you'll need the software update which only GE technicians can provide.
Regulates and circulates cool air within your refrigerator, ensuring consistent temperature. Görseli
Ürün
WR49X25197 - GE Refrigerator Evaporator Fan Motor
$136.99
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Thanks for the information Matt, it makes sense that this would be the problem. But my serial number is AF501021. Whic this still apply if I am outside the mention serial number range?
tarafından
It might. I don't have access to current service bulletins so it is entirely possible that they expanded the scope to include your model. Given you already replaced the fan I can't see how replacing it again would make any difference, which leads me to believe that the software update may in fact be required. I will do some research and check with some colleagues in the industry to see if there is any further detail.
tarafından
What was the part number for the fan you replaced?
tarafından
Yorum Ekle
Yanıtını ekle
Thomas K sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 325
