Nikon Coolpix P950 LCD Display show light no image, viewfinder works.
Your List of cameras does not show my specific model.
My Nikon COOLPIX P950 work as designed save for when turned on you can tell the LCD display has light.
Display will turn on and off when the EVF is actuated.
Have changed display.
Have changed out the complete back panel of camera with different camera same issue. There are two ribbon cables on the rear panel; the display cable and the back panel controls cable.
It may be a PCB/Motherboard issue, but I have no way to test it save for changing out the motherboard. Which I can do...But wanted to see if you have encountered this issue and may have a solution.
Having checked the internet a lot of people have the same issue with no resolution, one thread was to clean the EFV sensor and this resolved several peoples issue, I did this and it made no difference.
I reset the camera setting to stock, did not resolve my issue.
Have tried to update firmware but it will not enter into the update process.
Any help with this would be appreciated.
Regards
James
Bu iyi bir soru mu?
