What should I do with E4?
After working for a few minutes, it starts beeping and shows error 4 on the screen, I don't know how to fix it.
Update (07/18/24)
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Yes, you have a GE GBT412SIMII model dishwasher.
Is there standing water under the tub at bottom of the dishwasher?
If there is then it may be due to a leak in the dishwasher which has activated the flood switch
If there's no water it could be a faulty flood switch.
Tilt the dishwasher forward and check if any water drains out.
Unfortunately I cannot find the service manual (look behind the kickplate -toe plate to see if it is there in a plastic sleeve) or any parts for your model.
Bu yanıt yardımcı oldu mu?
There is no standing water under the tub at the bottom of the dishwasher. The dishwasher continuously drains, and if I add water, it drains immediately, making a sound as it does so. Since the dishwasher is built-in, I need to remove it to check further, but I don't have a screwdriver to take it out.
Son 24 Saat: 0
Son 7 gün: 27
Son 30 gün: 27
Her zaman: 27
3 Yorum
Hi @babakvakilian
What is the model number of the dishwasher?
jayeff tarafından
Hi @jayeff and thank you , is it correct ?
Babak Vakilian tarafından
