Ana içeriğe geç
The Xiaomi Poco F3 has a 6.67-inch AMOLED display with a refresh rate of 120 Hz and a touch sampling rate of 360 Hz. It is powered by the Snapdragon 870 5G. Released in March 2021.
Battery charge not showing correctly.
My Poco F3 still charges however the battery percentage shown on screen does not increase from whatever was showing when charging started. When it is disconnected from the charger it continues to show the phone discharging until it gets to 0% and switches off. I then turn it back on and it jumps up to 85% charge and continues to work and discharge until it actually runs out of power and turns off at some "random" charge %. It then tries to turn back on but turns off during power on sequence. I then place it on charge and it turns back on and shows 85%. I'll leave it on charge for a while at 85% then the cycle begins again.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@gmc46728 the State of Charge is reported from the battery to the phone. This could be an issue with a failed battery control board. I would suggest that you replace the battery and then re-evaluate. Use this guide Poco F3 Battery Replacement to replace the battery. Replacement batteries are readily available at many online stores.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
GMC sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 73
Her zaman: 488
