Ana içeriğe geç
Ağustos 2014'te piyasaya sürülen Lenovo Y50-70 Touch, Lenovo'nun Y serisi dizüstü bilgisayarlarının bir parçasıdır. Harici bir grafik kartı ve 15,6 inçlik dokunmatik ekran ile donatılmış olan Y50-70 Touch, oyun odaklıdır.
How do you repair usb controller?
I bought a motherboard that works mostly except that the usb ports don’t work. I’ve tried plugging in a mouse to the ports and the mouse does not work. When I plug it into the port not attached to the motherboard, I get a power surge.
Is there any way to find the chip that controls the usb ports and replace it with a chip from another board?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
6 Yorum
@gregoryvenezia sure, anything is possible. Here is the challenge. WE need to know what motherboard your Lenovo uses. It will be printed right on the board, most commonly on the side that faces the keyboard :-)
We need this so we can determine if there are any schematics to identify the IC and find a replacement for it.
tarafından
My motherboard is LA-B111p.
tarafından
I have a soldering iron and a heat gun. I don’t know how to re-ball solder.
tarafından
@gregoryvenezia
Did you check the USB power management setting in Device manager to see that the USB power hasn't been disabled?
Go to Device Manager > Universal Serial Bus controllers > right click USB root hub entries (check all of them) > Properties > Power management and ensure that the checkbox which states "Allow the computer to turn off power to the device" is unchecked.
Also check in BIOS if there's a setting allowing the USB ports to be disabled.
tarafından
What about the power surge?
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @gregoryvenezia
Here's a link to the schematics.
Do the USB ports show in Device Manager?
If so that indicates that the USB controller (it is integrated in the motherboard chipset and is not an individual USB controller) is working, up to a point anyway i.e. BIOS to USB controller is OK but not USB controller to USB port.
You will have to trace the 5V USB power supply and the data lines back from the USB ports using the schematic and check where they end up.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Gregory Venezia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 341
