Ana içeriğe geç
Compatible Touchpad Replacement Parts
I am trying to replace the touchpad as it has a constant Error code 10 when trying to connect, through reinstalling the drivers and updating them it doesn't work. Are there compatible touchpads from other laptops that I can use in place of it? I am having trouble finding a replacement touchpad which I believe is the problem.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @kylew87212
Check if there's a part number on the touchpad and search online for the number to find suppliers.
Here's the hardware maintenance manual for the laptop that may help.
Go to p.59-p.60 to view the procedure to remove the upper case with keyboard assembly, so that you can see if there is a part number on the touchpad.
The parts list for the model, doesn't show the touchpad as a separate item as it is most probably included as part of the C-cover with keyboard assembly. Click on Machine Type > Select Commodity to see all the available parts and their part numbers.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I looked up the part with the stickers on the back it looks like the vendor was CNY the P/N: was PK37B01FL00 P531003290000AEJ
it came up with nothing but I am probably going to look into what you mentioned because it would get me the part but the keyboard would be a waste unless someone brings me a broken keyboard.
tarafından
Yorum Ekle
Yanıtını ekle
Kyle W sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 22
Her zaman: 339
