Ana içeriğe geç
show generator code 4 instead of 1
hey, fellas need help with vellylab force fx c esu as it shows the generator code 4 instead of 1 . after calibration, the error 212 remains constant.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @abhijeetchauhan
According to p.6-10 (p.132/214) of the service manual, a code 4 error indicates a CPU test failed.
An error code 212 (see p.6-17, p.139/214) indicates a ram malfunction.
Try replacing the coin cell battery in the generator, then recalibrate it and check if that resolves the problem - see Correcting Battery-Backed RAM Malfunctions on p.6-26 (p.148/214). The coin cell battery model number should be stamped on the battery. Note: Be sure to remember which way the original battery was inserted so that you insert the replacement battery the same way
Bu yanıt yardımcı oldu mu?
Puan 1
9 Yorum:
hi @jayeff
Thank you for the detailed explanation. I understand the steps you mentioned regarding the error codes. However, my concern is that even after recalibrating the equipment as per the manual, the error code 212 persists.
Additionally, I'm noticing something unusual. According to the VellyLab FX-C manual, the generator code should be 1 for the VellyLab C model and 4 for the VellyLab 8C model. In my case, I’m working with the VellyLab C model, but it’s displaying a code 4 instead of 1. Could this be related to the unresolved issue? Any further guidance on this discrepancy would be appreciated.
tarafından Paylaş
@abhijeetchauhan
Did you try replacing the coin cell battery as suggested?
It is related to error 212
tarafından Paylaş
I have same problem what should i do solve the problem error 212 and 216
tarafından Paylaş
@mdabdulawalawal
See my answer regarding 212, it relates to 216 as well. Read the manual (linked above) about 216.
tarafından Paylaş
I followed your instruction and set date and time but not remove error 212
Reenter the calibration mode and then date and time ok
But not remove error 212.
Have any option to manually remove the error 212.
tarafından Paylaş
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
abhijeet chauhan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 600
