Ana içeriğe geç
Crosley Musician Eğlence Merkezi olarak da bilinir.
CD drawer stuck closed.
Where is the auto release hole located?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @jameshubba14635
There is no release (or eject) hole in the CD unit.
Use a thin flat tool e.g. flat metal spudger or even a suitably thin knife etc and slide it gently under the CD tray, on the left side until you feel the catch release.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
It didn't work. I felt something catch but which way should I move it? I tried up/down/right/left
tarafından
didn't open.
tarafından
Yorum Ekle
Under the disc port there should be gears on the left side use a flashlight and look into the hole and grab something thin hard and long enough to fit in the hole I used a knife but all you do is push the gears and they should start turning and when the disc slider pulls out enough for you to be able to grab it pull it out the rest of the way
Puan 0
Yorum Ekle
Yanıtını ekle
jameshubbard sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 56
Her zaman: 839
