Ana içeriğe geç
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
IE solenoid fails even after replacement
Getting IE error on machine and buzzing sound.
smacking solenoid on cool water intake takes care of problem temporarily
Replaced intake valve twice and works temporarily for a week or two. Then fails again.
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi @sashadkosloff
What is the model number of the washer?
Have you checked the wiring connections are secure not corroded etc?
Were the solenoids damaged and needed to be replaced each time or just not working correctly?
Have you checked the power supply to the solenoids to make sure that it is the correct value and is OK?
tarafından
Model: 41272211
Wiring seems okay
Solenoid just not working
Have not checked power supply yet, it’s running at this moment but will do that.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @sashadkosloff
If you mean 796.41272211 then here's a previous answer regarding the model on ifixit, that may help.
Constant voltage to dispenser solenoid
It's not quite the same problem, but buzzing sound would indicate problems with the power being supplied to the solenoid and that comes from the control board.
Perhaps check the control board for any obvious component damage. If there is then I can't find a schematic for the board and it is no longer being made by the manufacturer (LG makes the washer on behalf of Kenmore so it's all LG parts)
If the board is faulty there are still a few suppliers that have the board if you wish to replace it. Search online for EBR74798611 (examples only) to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks it probably is a control board issue. Oh well.
tarafından
Yorum Ekle
Yanıtını ekle
SASHA D KOSLOFF sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 88
