Ana içeriğe geç
Discover repair information including guides and tips for Whirlpool Refrigerators. Our comprehensive resources offer detailed instructions for troubleshooting and fixing common issues in various Whirlpool refrigerator models.
ice maker compartment too warm
Ice maker at 15 degs, freezer at -6. Replaced the unit, oem, made 3 cubes and quit. Figure it is the damper or the control board, or ? How can I be definitive?
The model number is correct but the unit is French doors above, a refrigerator drawer, freezer drawer below. While under warranty had the ice maker replaced 3 times. Now it is on my dime.
Update (08/31/24)
The refrigerator side is at 35 degrees. The damper I refer to is the mechanism that controls the temperature in the ice maker compartment
Update (09/03/24)
wrx735sdhz03
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum
Hi @colonelr
What is the full model number of the refrigerator?
tarafından
@jayeff. WRX735SDH
tarafından
@colonelr
Please confirm the full model number of the refrigerator?
As can be seen from this link there are 23 different model variations and they don't all have the same features or work exactly the same way.
tarafından
Further troubleshooting: took the damper out an fixed it to remain full open overnight. Ice maker temperature = 13 degrees, refrigerator = 29 degrees. However, it had made one tray of ice. Returned the damper to normal operation.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @colonelr
Doesn't seem like the damper is the problem then.
Here's the tech sheet that may help.
Run Service test #18 Ice door motor and check if it works OK.
Also try Service test #36 Ice box fan to verify that air is being blown to the ice maker.
If you do find the problem and it is a faulty part, here's the parts list. Locate the wanted part in the list to find the manufacturer's part number for the part that is listed with it. Search online for the part number, to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
All tests checked positive. No malfunction. The ice maker suddenly started working and made ice for about 4 days. Quit, for 2 days and restarted again. Temps are 11 deg F in the ice maker. That is where I am today. Making ice with no idea of what is going on .
tarafından
Yorum Ekle
Yanıtını ekle
Colonel R sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 200
