Ana içeriğe geç
Repair guide, disassembly, and troubleshooting information for the Logitech MX Master 3S wireless mouse. Released in 2022 and identified by model number MR0077.
Solid Red LED with no connection to the target
My MX Master 3S always has a solid red LED on it. After every power on and off, I can see a green LED come up. Below, I can see the mouse in pairing mode, and it appears on my laptop as well. But then, after 1 minute, it turns to solid red, and I cannot see it anymore on my laptop.
Could this be a loose connection? Or does it require a battery replacement? I have a 2S and 3, all of which show that they are charging by blinking LEDs in both mice, but for my 3S, it just shows a solid red even when it is being charged. I have already charged it for 3 hours, but the same behaviour.
I have already changed my dongle to the universal bolt
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
Thank you very much @jayeff for your reply.
A very stupid question, so I just take out the battery and check the voltage right away right? And it should be around 3.8V? It won't matter on the state of charge within the battery.
tarafından
@peekabooboo
You said that you have already charged it for 3 hours so after this amount of time it would be very close to being fully charged so the voltage should be at least 3.8V.
tarafından
Understood. Thank you.
I will check this and come back here just in case and follow the guide you have attached. Thank you very much
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @peekabooboo
If you have a DMM (digital multimeter) check the voltage of the battery in the mouse to see if it is OK or not i.e. approx 3.8V DC.
Here's the ifixit Logitech MX Master 3S Battery Replacement guide that may help.
If the battery is faulty ifixit sells a battery for the mouse (see guide) or search online for 533-000205 to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hello,
I checked and it has 4.11V
tarafından
Yorum Ekle
Yanıtını ekle
Peekabooboo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 45
Her zaman: 452
