Ana içeriğe geç
Ekim 2024'te piyasaya sürülen, Apple'ın popüler Mac mini küçük form faktörlü masaüstü bilgisayarının üçüncü büyük yeniden tasarımı için onarım rehberleri, sökme talimatları ve sorun giderme bilgileri. M4 ve M4 Pro SoC'ler ile en az 16 GB birleşik bellek içerir.
How is the SSD installed
Is the SSD soldered?
Bu iyi bir soru mu?
Puan 17
2 Yorum
it is not soldered in but like the Mac studio you still can not replace with larger according to people who have been trying today
tarafından Paylaş
Apparently Mac Mini with M4 Pro has different main board layout and its SSD module has non-standard shape.
https://support.apple.com/en-us/121003
tarafından Paylaş
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Resim
It's not soldered
Bu yanıt yardımcı oldu mu?
Puan 32
10 Yorum:
How did you open it up? I also see that only shorter SSDs fit into that place.
tarafından Paylaş
Thank you very much. So I could exchange the SSD myself? How difficult would you rate this process?
tarafından Paylaş
wooooo what is this? 2230?
tarafından Paylaş
@nitro912gr If it is the same style as in the Mac Studio (which knowing Apple is a big IF) it is a proprietary NAND and that’s all. Luckily there has been work for upgrading the Mac Studio so if Apple keeps it all the same it should probably be a drop in replacement. If it is different then in time I imagine it will get reverse engineered just like the Studio in the coming months.
tarafından Paylaş
One slot? Only, in Studio has two ;)
tarafından Paylaş
5 tane daha yorum göster
Yorum Ekle
It's removable, but is it drop-in replaceable? We see that they are already using proprietary connections for it which is to be expected of 2013-2017 Apple, but keep in mind that the more recent Mac Studios had firmware locks to prevent people from simply swapping out their SSDs as they would on any other machine.
I would love to get one of these Minis, but it would suck if Apple threw a fake bone to the right to repair community.
Puan 1
2 Yorum:
No, it’s not a simple drop in! Even when the 3rd party modules become available, without a second system to run Configurator2 (DFU Mode) to process the Flash module (aka NAND) so it’s married to the system. Then prep the drive and install the OS with the last step restoring your stuff from a good backup.
tarafından Paylaş
@danj 👍 thanks, you clear explained the process to mod original ssd ;-)
tarafından Paylaş
Yorum Ekle
The SSD is removable and upgradeable, there are 3rd-parties managed to produce a compatible SSD card that fits into the proprietary slot. With the same or compatible NAND chips on the replacement SSD card, upgrading the SSD on the Mac mini M4 turns out to be quite feasible.
Puan 0
1 Yorum:
Not that easy if you need to build it first!
tarafından Paylaş
Yorum Ekle
Just like the previous model and how all of the M Series MacBook systems the RAM and storage (Flash) is soldered to the logic board. Only the Studio and Mac Pro systems have custom Flash storage modules, not a true SSD.
Puan -2
8 Yorum:
It's not soldered down. Get your facts right and stop assuming it's like earlier version.
tarafından Paylaş
Yeah get your facts right mate!
tarafından Paylaş
Hey @joehill58422, Chill out a bit. this was before the new post.
tarafından Paylaş
Bro I’m only playing with ya lol
tarafından Paylaş
I’m happy what I was told was wrong!
tarafından Paylaş
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Douglas Smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 109
Her zaman: 39,737
