Why is it not charging?
why is it not charging?
Bu iyi bir soru mu?
Have you tried a different known working charger or charger cable to check if the phone starts to charge?
Has the phone been dropped or gotten wet at all?
Use a strong light and a magnifying glass to visually inspect the charge port enclosure for any dust or lint that may be preventing a good electrical connection.
If there is any debris in the port enclosure, do not use a pin or probe to try and get it out as you may damage the pins or cause electrical problems in the phone. Try using a vacuum cleaner to suck it out.
If still no good the phone will have to be opened and inspected and tested as to what the problem may be. Here's a teardown video that may help with the disassembly
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 80
