Ana içeriğe geç
The Sony Playstation 2 SCPH-790xx is the fourth revision of the Playstation2 slimline model.
Ps2 doesn’t show browser/configuration screen
Really strange one, console boots up and shows the PlayStation loader like normal, but then without a disc in it doesn’t come up with Browser/configuration, it just goes black.
Very strange, it loads games up fine and works perfectly other than this.
Help! Thanks, Luke
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi Luke!
Is the console modded? Because it sounds like it is.
Anyway, it's possible that the modchip is broken or not configured correctly.
I can't help you with the modding part, but I recommend to remove it, if it's there.
If it's not modded at all, then it's broken on firmware level. This is very difficult to fix and basically a motherboard replacement is required....
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Hi mate! Thanks for the response once again!
How can I tell if it’s modded? I’m assuming you mean at hardware level, if you let me know what to look for I’ll open it up and take a look!
Thanks, Luke
tarafından
No problem :)! Yeah at hardware level! When you open it, using this guide: PlayStation 2 Slimline Motherboard Replacement
You will probably see a chip with a LOT of cables soldered on to the motherboard. That would be the mod chip! You can share photo's with us if you are not sure! Thanks :)!
tarafından
Yorum Ekle
Yanıtını ekle
LukeResells sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 68
