Why wont my 2ds xl charge?
I replaced the battery on my “New Nintendo 2ds xl” due to the device not charging. Now the charging light will turn on for a little while and then will suddenly turn off. Any suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum:
What was the original issue? Did the orange light also came up with the old battery? Or not at all? It's possible that your replacement battery is faulty.
tarafından
Before I changed the battery it had the same issue with not charging and the light acted the same. The new battery has great reviews so I dont think thats the issue but it very well could be. Is there anything else you think the problem might be if the battery isnt the problem?
tarafından
Someone did had the same issue here: Orange LED turns on for 5 seconds then shuts off when plugged in
It could be a Fuse, but then you do need to take the motherboard out and do a continuity test with your multimeter!
tarafından
Youre the goat. Thank you
tarafından
Trying to do my best hahaha
tarafından
Yorum Ekle
