Ana içeriğe geç
The Satellite C660 is a series of laptops released by Toshiba around 2010. They have 15.6-inch screens and a variety of Intel processors.
will not boot goes straight to bios with HDD/SSD not installed
was working now wont boot to windows found no 12v to HDD all other voltages present 3.3/5/19 checked on board fuses cannot see any componants that look faulty i cannot find a mother board voltage test point schematic , i have all test/repair tools HELP !
Bu iyi bir soru mu?
Puan 0
10 Yorum
thanks for your input laptops aint my area i repair games consoles & retro audio , So according to the pinout map on a sata it's 3.3/5/12v yes i have a no HDD/SSD installed i have looked at the bios settings changed things back and forth to no avail security setting supposed to lockout hdd sync i cannot access have tried everything also tried 2 other drives that boot in my backup laptop , cannot workout whats happend it was working one day now it's not no trauma not dropped or moved , i will get the board version & number tomorrow & post tomorrow , thanks again ...... P/s cmos battery good
tarafından
@lesliebrow19476 try a BIOS update and see if that gets your BIOS to see the drive again.
tarafından
@oldturkey03 How is that done via my backup ?
tarafından
hello again' looking at a bios update the way it's done is when the Pc boots up , update is via Toshiba service site thats not possible the other method is by memory stick thats not possible , i am considering replacing the bios chip with a virgin chip since a bios chip is an Eprom it cannot be erased only with programming software which i dont have
tarafından
@lesliebrow19476
If it goes to BIOS can you alter the boot menu to show USB 1st boot option and then insert a bootable USB recovery drive, save and restart and check if it finds the HDD?
tarafından
5 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @lesliebrow19476
For what it's worth, here's a composite image from the motherboard schematic showing the sata HDD connections to the chipset and the power supplies.
Hopefully it may be of some help.
(click on image)
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Thanks very much' do you see the 12v pinout on this map on my pinout map those last pins are numbered 1 - 15 that was what i was going on , thanks again much appreciated
tarafından
@lesliebrow19476
All the v12 (12v?) connections aren't connected. Seems like a standard 24 pin connector is used and wired accordingly for a 2.5" sata HDD/sata SSD.
tarafından
That will be a big help tracing the tracks i'm unsure if it's a multi layer board' again thanks best to walk away & leave it for a few days then look again with fresh eye's learned that lesson long ago' .....
tarafından
Yorum Ekle
En Yararlı Yanıt
@lesliebrow19476 there should not be a 12V rail. The 2.5" laptop HDD typically uses only 5V. Double check with another drive since this issue is either your drive, or a bad master boot sector. You are not telling us if the drive is being seen in the BIOS.
We will need to know the exact model of the motherboard. It should be printed right on it. The laptop make and model will not give us the results we need to work on a schematic.
Puan 2
Yorum Ekle
Yanıtını ekle
leslie brown sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 229
