Ana içeriğe geç
Apple Logo Appears Only Once When Plugged In
Hello everyone!
First of all, I do not know which version of Apple Watch this is. Someone gave it to me, but did not tell me which model it is. I believe it is an Apple Watch SE, but I am honestly not sure.
Well, the Watch simply does not turn on. When I connect it to the MagSafe Charger, I see the Apple Logo for about half a second, and then it disappears. If I play with the buttons a little bit, sometimes I can get it to turn back on... but the Watch itself I cannot get to boot. I would think this is either and issue with the battery or the button itself. Since I have little to no experience with the Apple Watch, I figured I would like to hear from you guys before I get inside. What do you guys think this issue is?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
5 Yorum:
Hi @jadonlyon
Check on the back of the watch as all the information regarding model etc should be printed on there
tarafından
42mm case • 7000 series aluminum • ion-x glass • composite back • serial fh7r6blzg9j
tarafından
@jayeff - I am not sure if this helps
tarafından
@jadonlyon
7000 series indicates that it is the original Apple watch i.e. the very 1st one released. Not to be confused with an Apple Series 1 watch which came next.
ifixit still has some parts for it but not many.
tarafından
@jayeff - Oh, that's old....
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
@jadonlyon
Yeah.
Given its age most likely it is a battery problem if it has never been replaced and if it hasn't been charged for a long while.
Update (12/21/24)
@jadonlyon
I've changed the device you selected for your question to the correct one for the model.
Click on the Apple watch - original icon (to the right of your question) to see the ifixit repair guide.
Cheers
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
@jayeff - Then I will check that first. Thank you!
tarafından
@jayeff - Thank you so much!
tarafından
Yorum Ekle
Here’s the guide to replace the battery Apple Watch batarya değişimi iFixit still has replacement batteries for this series. Make sure you get the kit as you do need a few other parts s well.
Puan 0
1 Yorum:
@danj - Thanks for this info
tarafından
Yorum Ekle
Yanıtını ekle
Jadon Lyon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 361
