Ana içeriğe geç
Taşınabilir buz makineleri, buz üreteçleri ve buz makineleri dahil olmak üzere buz yapma cihazları için onarım ve sökme rehberleri.
Ice Machine Fan Does Not Run Properly
My family's ice maker, a Frigidaire EFIC117-SSBLACK-CU, has run an extended service of, if I have this right, at least 5 years of frosty production. Recently, however, the machine has begun to malfunction in a few ways.
The first issue to come to light was the fact that the fan that the machine had come with had stopped working. The device uses a PY-1225H12S fan for internal cooling. I replaced this fan and got the machine to work again. At least, for a while.
I somehow managed to not take the leakage of water present within the machine more seriously. The ice maker has a tube, which I measured to be 1/8 in. inner diameter, 1/4 in. outer diameter, that is used to transport water from the bottom of the machine's water reservoir up to the cooling rods, which are used to create ice, of course. The newer fan that I had installed recently stopped working properly, just two months after its installation. The first fan had shut off entirely, causing the device to overheat, and the second one jolted to attempt to spin, but could not. Spinning the fan manually as the machine was powered on would give the fan a tiny jump, but the fan would blow incredibly weakly, still permitting the system to become extremely hot, as in the case of the first fan.
Upon yet another disassembly, I discovered that the tubing was ruptured at the end which deposits water in the freezing area of the ice maker. This is what I suspect caused the first fan to die. And, I also figured that the second fan stopped working properly due to the leakage from the tubing. So, I ordered more tubing online, as well as a third replacement fan. I bought the incorrect tube size as of now, which brings me to not being able to cover that fix.
But even when wrapping paper towels around the tube where the leak occurs, and after having installed the third fan, I found that this third fan has the exact same problem as the second fan: the fan jolts and, with a start, moves a little, but not nearly enough to maintain a low temperature for the ice machine.
At this point, being a relative novice in repairs, I am stumped as to what else could be the issue, as to why the fan is not moving properly. Any help to guide me in the right direction would be greatly appreciated. Thank you for getting this far.
(P.S.: I would upload pictures, but I keep getting infinite loading thumbnails on the images I upload. And if I try to view the images, access is denied...)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @theflamethrower
For the fan to run correctly it needs 12V DC power being supplied by the control board.
As it is only a 2 wire fan i.e. not 4 wire, therefore no inbuilt fan temp sensor and speed sensor, use a DMM (digital multimeter) and check that when the fan first starts that there's 12V DC when measuring between the fan's red wire and either the fan's black wire or an earth point i.e. screwhead or a bright, shiny, non painted, clean metal point on the chassis. Then measure what voltage is there when the fan stops.
Unfortunately there's not much information online regarding service manuals or wiring diagrams but it may be worthwhile knowing whether it is insufficient voltage or a total lack of voltage that is the problem.
Is there door switch (lid switch?) for the ice maker at all? In refrigerators the cooling (evaporator) fan is turned off when the correct temp is reached or the door is opened and only starts again when the door is closed and if the temp is above the preset upper limit and needs to be lowered again. So perhaps it may be the same for the ice maker.
If there is a lid switch, it could be that if it is faulty or perhaps if the temp sensor is faulty, then that may be the reason the fan stops. I'm assuming that the ice maker doesn't get to the correct operating temperature?
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Definitely sounds to me like insufficient voltage being sent to the fan. And since this sounds like it is the condenser fan... that's not good for the system. Might be a transformer issue, or another component on the board. I'm going on a limb and guessing the transformer is part of the control board as well, as this is the most common setup with small machines like this.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Aiden sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 87
Her zaman: 1,772
