Ana içeriğe geç
Inspiron 1318, Dell tarafından üretilen bir dizüstü bilgisayardır. Bu sayfa, Dell Inspiron 1318 için onarım ve servis bilgilerini içerir.
Difficulty unscrewing laptop case
I am currently attempting to open the laptop case because a metal hinge piece has broken off and the piece sawed the display cable open, so I would like to remove the display and use the VGA port instead. However, I need to open the case in order to remove the cables connecting the display. There are three screws on the bottom half of the laptop that I am having difficulty with. One of the screws wiggles but will not come out, no matter if I try unscrewing it further, try removing it with tweezers, or try turning the laptop around and shaking it to make the screw fall out. The other two screws will not turn when I try unscrewing them, and sometimes I can see metal shavings on the end of the screwdriver. I am using the size 0 Philips screwdriver bit. Any suggestions for removing the last three screws?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @lynx20434
Try one of the methods suggested in this Most Helpful Answer on ifixit
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I would suggest leverage, or a tighter bit? l
Puan 0
Yorum Ekle
Yanıtını ekle
Lynx sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 274
