Kenmore 700 series “lid” error
Kenmore 700 series, model 110.28102310
Problem
Washer is showing “lid” error on its display, despite the lid being closed
Troubleshooting steps
- Original trouble came from a family member overloading the washer. This yielded a dU error code (door can’t unlock, even though the door was totally unlocked and free). I cleared this with a simple unplug and replug.
- The dU code appeared intermittently and was resolved the same way for a few weeks until it finally would not clear on power cycle.
- I don’t believe the issue is due to lid lock assembly. I’ve now replacethat (WPW10619844), but after powering it back up and trying to start any cycle, I get a “lid” error on the display for “lid left open,” which it is not. I cannot clear this error by any means. The original lid lock assembly now shows the same thing.
- If I pull the sliding lock out through the strike plate, then turn on the washer, it will snap back through and show a dL error code (“door cannot Lock”). I can reset that by power cycle.
- I don’t believe the control board is at fault, but I’ve ordered a replacement in case.
Bu iyi bir soru mu?
