Ana içeriğe geç
Repair guides and support for top and front loading Whirlpool brand washers.
Off Balance when spinning
Whirlpool LSQ7030LQ0 washer. Off balance when it spins. I have replace both sets of suspension pads, all 4 suspension springs and checked that the balance ring has fluid in it. What else can it be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Does it do it if you spin it empty? If not, then it is the clothes distribution.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Yes. It does it empty. I just noticed that it is rubbing the bottom of the tub ring as it spins to the point that it is creating a bur on it.
tarafından
There is a part, I have never replaced one but I have heard others replace them, under the tub. I can't remember what they called it. Could be a stem, seal and bearing. It isn't an easy replacement but it can be done. That would tilt the tub and cause your symptoms, I suppose.
tarafından
Yorum Ekle
Yanıtını ekle
Randall Tipton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 100
