Ana içeriğe geç
Released September 16th, Apple's "smaller" flagship smartphone features a 6.1" ProMotion OLED, a triple-lens rear camera system, 5G, and a newly designed "Dynamic Island" around the front-facing camera and top sensors. Successor to the iPhone 13 Pro.
14 Pro display won’t separate from frame
Hello,
I recently purchased a replacement battery for my 14 pro. I'm using the provided suction cup and a hairdryer. After removing the 2 screws, I tried heating the bottom edges multiple times, providing constant pressure, slightly pulling up and down, and also heating while pulling on the display.However I could not get the display to budge enough to get the pick inside. Anyone have this problem, and any tips for the next time try?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi, what i allways do is put some 90% alcohol on the side of the screen to loosen the frame adhesive. Then heat the frame/screen at about 100 degrees celcius and i use a verry thin metal scheed (for example feeler gauges to adjust the contact point of my car engine) i hope you know what i mean, because a rasorblade is a little bit to thick. And put this thin metal sheet between the screen and housing and when there is a small gap i put a drop of alcohol to weaken the adhesive. Sorry for my poor english.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Arvid Huq sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 36
