Ana içeriğe geç
Japonya'da 12 Aralık 2004, Kuzey Amerika'da 24 Mart 2005 ve Avrupa'da 1 Eylül 2005 tarihlerinde piyasaya sürülmüştür.
PSP 1001 Right Trigger Unresponsive
Basically I haven't used the PSP in some time and after starting it again I noticed the right trigger is toast, doesn't respond to any clicks.
Anyone know what might fix that?
Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Alex!
Someone did made a video about how to fix this!
Link: https://youtu.be/edSyysTaAGg?si=0MtDtEgR...
Part:
https://a.aliexpress.com/_EzjnG9i
I repaired many of them and it’s easy! You need to replace the whole flex cable and after this it should be fine.
You need the PSP1000 one. If you have any questions, please let us know!
Bu yanıt yardımcı oldu mu?
Puan 1
8 Yorum:
Interesting! I'm a little indimitated at how many parts seem to be in the console but I'll see if I can give that a shot. I'm guessing it's more or less you unscrew the whole thing and simply replace that part you order for it?
Thanks!
tarafından Paylaş
Hi Alex! Yes that is correct. You need to take the front cover off, then the home button, volume buttons, etc bar, be careful to take it out the connector, all of them are very fragile. And then remove the LCD (it's still connected to the motherboard, so again, be careful). Then take the right board out. Follow this guide: PSP 1000 Anakart Değişimi (till step 16) and then put the new part in and reassemble it again. Good luck and be careful!
tarafından Paylaş
Gonna aim to try that. Thanks Again!
tarafından Paylaş
My pleasure!! Good luck with the repair!
tarafından Paylaş
I replaced the cable on my own psp 1000. All the buttons work with the new cable except for the right trigger (the one I was trying to fix). Any ideas an what to do?
tarafından Paylaş
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Alex Reichmann sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 92
Her zaman: 1,638
