Ana içeriğe geç
Repair and troubleshooting information for the FixHub Power Series | Portable Soldering Station, the combination of the Portable Power Station and the Smart Soldering Iron. Released in October 2024.
FixHub won’t charge out of the box.
Just opened up my set I got as a gift. The iron works great but the hub won’t charge. I put it on a charger that reports draw and it just keeps cycling on an off at 0.1w. I also tried to connect it to my computer to see if the online tool worked but no luck. I have also tried 3 other usb c cables to no luck. I also took the unit apart and disconnected and reconnected the battery.
Guessing I may have a lemon but wanted to check here first…
Bu iyi bir soru mu?
Puan 8
6 Yorum
@justinm36946, Sorry about this. This is not the experience we want you to have. @jayeff is correct, please contact support@ifixit.com to get you back on track.
tarafından
@krisrodriguez Sounds good. I sent a message when I wrote this as well. Though I have not heard anything yet. What is the usual support turn around time?
tarafından
@justinm36946, we do our best to get back to you within 48 business hours. Please keep in mind that we're a small team so response times can vary from time to time. If you don't receive a response within that timeframe, you can reach out to me here in this thread, and I'll follow-up with the support team on the delay.
tarafından
Hi.
I just received my Hub today as well and I think I have the same problem.
I tried different chargers, normal USB-A to USB-C, USB-C 30W (Apple iPhone Charger) and an Apple MacBook Charger 60W and of course with different cables as well.
But, nothing helps to charge the station. The soldering iron works fine.
Is this another .. bad package :(
tarafından
@rene51173, thanks for reaching out and I'm sorry to hear you're having problems with the hub. Have you reached out to our customer support department yet?
tarafından
1 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @justinm36946
There seems to be teething problems with the device, as you're not the only one having some problems with it.
Contact ifixit and check if there's a solution available
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Hello @justinm36946, it sounds like you may have experienced what I went through 5 months earlier (except perhaps without the issue with firmware version 1.4.0), as I've detailed in another thread here.
The direction you want to head in is: the battery could've been completely drained and won't turn on (with the firmware preloaded onto the FixHub out-of-the-box), but you should still be able to eventually get the FixHub and the soldering iron firmware to update in DFU mode with a data-enabled USB-C to USB-A cable using the FixHub WebUSB console page. (For more info, consult the "Further Troubleshooting for Unresponsive Unit" section on the support page for "FixHub Power Station Not Turning On".)
Puan 4
Yorum Ekle
Yanıtını ekle
justinm sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 25
Son 30 gün: 84
Her zaman: 813
