Ana içeriğe geç
Samsung Galaxy S8 Active, SM-G892A (AT&T) ve SM-G892U (T-Mobile ve Sprint) model numaralarıyla tanımlanabilir ve Ağustos 2017'de piyasaya sürülmüştür. Samsung Galaxy S8 Active, Samsung Galaxy S serisinin sekizinci nesli olarak Samsung Electronics tarafından üretilen bir Android akıllı telefondur.
Samsung S8 active overheating
Everything turned on normally, heating at around 50°C on the motherboard whilst charging
here are the temperatures, hope y'all can help me
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
You need to open up the phone and see the component that causing the heat using a thermal camera. Sorry but I guess you need to take it to a technician.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Heating more than normal while charging is a sign your battery needs replacing.
If the battery over heats, it will obviously heat a lot of other things since it covers a large area.
Do a battery test and see if that gives a clue.
Puan 0
Yorum Ekle
@jamesleebron connect an ammeter between your charger and your phone. See how many amps it is pulling. This can be an issues of the charging circuitry (bad PMIC, failed Battery controller etc.) Make sure that you have a good USB cable and that your charging port is in good working condition. Check the pins for corrosion etc. After that you will have to open it up and check for any damaged or disconnected components. A new battery is always advice but do not ignore the charging board Samsung Galaxy S8 Active I/O yardımcı kart değişimi
Puan 0
Yorum Ekle
Yanıtını ekle
James lee bron sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 194
