Ana içeriğe geç
Repair guides for DJI's 3rd lightweight mini drone. The DJI Mini 3 Pro was released in May 2022. Model number: CP.MA.00000488.01.
7 Soru Tümünü görüntüle
DJI RC remote batteries drain after 45 minutes
I have the DJI RC that I use with my drones. The battery life should be 2-4 hrs but I only get about 30-45 minutes of run time on mine.
In the past I’ve drained the batteries until the remote shuts down, then I’ve opened the remote and unplugged and replugged the batteries. After that the remote shows that it has about 65%-70% battery left, when I haven’t even recharged it from the first time. The remote then works great for a few more weeks, then it starts having issues again.
Any ideas to why this happens?
Is that because of bad batteries?
Bad software? (I’ve factory reset it 2 times)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
I would suspect the battery contacts might be corroded. Corrosion will cause a high resistance that reduces the voltage to the unit making it think the battery is low. Removing and replacing the battery cleans some corrosion off making it work again - for a while.
See if you can clean and tighten the contacts.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I double checked, no corrosion.
tarafından
Yorum Ekle
Yanıtını ekle
Nate sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 20
