Ana içeriğe geç
The Technics SL-1900 is a 2-speed, direct-drive turntable with fully automatic single disc playback introduced by Technics in 1977.
1 Soru Tümünü görüntüle
Arm not staying on vinil
As soon as I lift the arm and put it onto the vinil to listen, it automatically goes back to the rest position....I am frustrated as at the moment I can't figure out why? canyou help?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The mechanism has a trip system that activates when the arm reaches the inside grooves.
Obviously, something is loose, misadjusted, or bent causing it to trip before it gets there.
There are many pieces to this, so if you are mechanically inclined you may be able to determine why it is tripping wrong by watching it.
Here is the service manual.
Remove the stylus before you start so you don't damage it.
You will have to get access to the bottom and maybe remove the platter and move it manually.
The platter should just lift off, so don't invert it before taking the platter off.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Miguel Geminiani sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 19
Her zaman: 19
