Ana içeriğe geç
New model released in 2022(?) F1502ZA-SB33: 15.6" screen, 12th Gen Intel Core i3 1220-P , 4GB RAM (soldered) with a single 8GB DDR4 SODIMM expansion slot, Windows 11, no optical drives.
Left side hinch make sound while opening and closing
While opening and closing my laptop, the left side of the hinch make heavy sound , but if I tighten the screws the sound is reduce for a week , then starts the same problem. What is the problem in my laptop? How to solve it? And how much will it cost?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@hari20790 sounds like either your hinges are starting to "gum" up and are hard to open, which will pull on the screws that hold it to the case. You could try something like a few drops of some sewing machine oil on the hinges to see if that frees them up a bit and changes the behaviour. If not, then it might be time to think about replacing the hinges.
Since there are no specific guides for the hinges, check through some of the YT videos https://www.youtube.com/watch?v=2Ur5s91F...
like this] or this guide Asus VivoBook F1502ZA-SB33 Back Cover Replacement to see how to get into your laptop. After that you will have to experiment a bit. If you are stuck somewhere, post a couple of well focused images with your question so we can try and help you further.
Here is the guide for that Adding images to an existing question
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Asus VivoBook F1502ZA-SB33 Back Cover Görseli
Kılavuz
Zorluk:
Orta
15 minutes
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
HARI sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 14
