Ana içeriğe geç
A 40" LCD TV from Sony released in 2014.
display come on and off six blinking light
six blinking light
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @kay73296
A 6 blink error code is a backlight error.
This could be due to either a faulty "B" board or a faulty screen (aka panel module).
Here's the service manual that may help to isolate it a bit more as to which is it. Go to p.20 and follow the 6 times blinking troubleshooting flowchart to see what you get.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Hi Kay,
I didn't have any more luck than you did finding any authoritative information, in particular from Sony itself, regarding those blink codes. Well, I did find an answer on the Sony forums for someone whose TV was blinking four times, but that doesn't really help us, does it?
What I did run across was a YouTube video of a repairman who got in a TV like yours with that same blink code. He seemed to be saying that the code is supposed to indicate a problem with the main board, but in his experience he felt that the sounds it was making was what you hear when there's an overcurrent condition. Apparently overcurrent issues are generally caused by the backlight LEDs, and sure enough when he opened up the TV he found two LEDs that were burnt out. Replacing them appears to have fixed the problem, although on the one he had there were a couple of pins on one IC that he felt the solder wasn't good on so he resoldered them.
The upshot appears to be that a backlight issue can cause the blink code you're seeing and repairing or replacing the backlight LEDs should hopefully fix the problem. If it was me, I would probably opt to replace the full set of backlights; in my thinking if two of them have gone out, how long will it be before more of them go out? Rather than taking a chance on having to open the set back up and do the job again, I would just replace them all; I strongly suspect it's not going to be all that much more expensive to do so.
Here the video; if you decide to go ahead and replace the backlights this video could give you some general direction, but it isn't strong on the exact steps needed to do the job so I might suggest you search up more backlight replacement videos for your TV model.
Sony KDL-40R470B 6 red blinks repair - YouTube
Hope that gets you going again. Should you go ahead with it, be sure to take lots of photos as you work, then once you're done you can use them to make your own iFixit guide to the backlight replacement! It's easy, fun and will earn the appreciation of the repair community. You could be the one to help the next person who comes along with the same problem.
Create a new Guide - iFixit
Puan 1
Yorum Ekle
Yanıtını ekle
KAY sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 24
Her zaman: 41
