Asus ZenBook UM431DLaptop keeps getting stuck in automatic repair loop
A few months ago, my laptop started occasionally getting stuck in an automatic repair loop. I was usually able to get out of it using some combination of system restore, uninstalling updates, and just turning it off and letting it sit overnight. I have no idea which of those was the solution but it worked. Then about a month ago, it got stuck and nothing would work. I eventually used a boot USB to get into the hard drive and transfer my files off, then reinstalled Windows 10 via USB. I figured that would fix it as I thought the cause was an update that got half installed before my laptop died.
Last night, I left my laptop closed and plugged in (but not powered down) for a few hours and when I came back, it had brought up the automatic repair screen again and nothing so far has worked to get back into Windows. Seeing as I completely reinstalled Windows 10, I no longer think it it's just an issue with my copy of windows and instead either the windows updates themselves don't work with my laptop, or there's a hardware issue. I can get back in the same way I did before, but it's a pain in the ass. Ideally I'd like to prevent this from happening in the future. How would I go about this? Is it even worth it or would it be cheaper/easier to take it to a repair shop?
Bu iyi bir soru mu?
3 Yorum
I was able to manually update the laptop so there are no updates pending, but when restarted it still does not want to boot into Windows properly. I think that narrows it down to a hardware issue. How do I figure out what the issue is so I can fix it?
Annaliese P tarafından
@annaliesep
Please expand on what you mean by "....still does not want to boot into Windows properly."?
Does it boot fully into Windows safe mode OK?
jayeff tarafından
@jayeff It will usually boot into safe mode if I select it in the startup repair menu, though the time I had to reinstall Windows it wouldn't boot into safe mode and eventually wouldn't even open the startup repair menu. Also in the time between my first post and yesterday's comment, I was able to boot into windows and use it with no problems for a couple weeks, keeping it in sleep mode when not using it. The only other issue I've noticed is sometimes the headphone jack stops working, but if I can get the computer to restart it will fix that.
