Charging problems with battery
My battery won't charge
Bu iyi bir soru mu?
@shirleylar63859 let's start off by clarifying what you have checked. Have you checked your battery? Have you checked your alternator? Use a voltmeter and measure the battery voltage between the positive and negative post. It should be around 12V Next, with your Passat running measure the voltage between the positive and negative post. What voltage do you get (expected is around 13.5V to 14V DC). If you have that voltage, it is most likely your battery. If you do not have that voltage, it could be your alternator. Let us know what you find out.
Bu yanıt yardımcı oldu mu?
well, you must start by doing something and letting us know what you did.
Your question is like my car won't run. What's wrong?
Start by taking it to AutoZone or Advance Auto, They can check the battery and alternator.
That alone will likely get you an answer.
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 179
