Ana içeriğe geç
Kapıdan su/buz pınarı veya buz yapıcı içermeyen, otomatik buz çözme özelliğine sahip 2019 model LG LFCS27596* buzdolabı hakkında onarım ve daha fazla bilgi edinin. Bu sayfa, LFCS27596* desenine uyan model numaralarına yönelik bilgileri kapsar.
CF E code after fan replacement.
I replaced the condenser fan on my fridge when this code popped up. It worked fine for like 24hrs then I noticed the sides of the fridge were hot again and it was throwing the code as well. I unplugged it and let it sit for about 10 minutes then plugged it back in and spun the fan my hand and it started working again. Now it is off again when I checked it about 16hrs later. Any ideas on what would cause this because I am out of ideas. Thanks for your time
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @dylanmcguire
A CF E error code indicates a problem with the condenser fan or condenser fan operate circuit.
Here's the start of the CF E troubleshooting section of the service manual that may help.
It the replacement fan is the problem, search online for EAU63923602 to find suppliers that suit you best. This is the part number for the condenser fan and it should be printed on the fan itself if you wish to verify that it is the correct one.
Ensures optimal airflow across the condenser coil in LG refrigerators by rotating when activated. Görseli
Ürün
LG Dc Motor Assembly - EAU63923602
$93.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Dylan McGuire sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 77
Her zaman: 951
