Ana içeriğe geç
Asko Appliances AB, buzdolabı, bulaşık makinesi ve çamaşır makinesi gibi ev aletleri üreten İsveçli bir şirketti. Merkezi, Västergötland'ın Vara Belediyesi'ne bağlı Jung'daydı. Asko Appliances günümüzde, Çinli büyük ev aletleri üreticisi Hisense'in bir parçası olan Gorenje Group'a aittir.
What is the Error code E10
what is the Error code E10 for Asko Dishwasher and how to fix ir.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
What is the model number of your dishwasher? Asko makes quite a few different ones, and getting you the correct answer depends on which one you have.
Knowing the model number is essential in this case, as a general search for Asko dishwasher error codes shows that most Asko DW's use error codes that start with "F" rather than "E", so we'll need to confirm.
The only result I came up with that seems to be close is a video on YouTube describing an Asko DW with an E10 error code. They claim it's a water level sensor error, which could be the sensor itself, the wiring going to it, or an issue with the control board. The only real helpful information they have to offer is to tell you to turn off the dishwasher, unplug it for a full minute, then plug it back in and see of that helps. If not, they say you should then call a technician. :-/
E10 Error on Asko Washing Machine - How to fix - YouTube
Update (04/10/25)
A search for Asko documentation on your dishwasher turned up a user manual, which includes a troubleshooting section listing error codes.
User manual Asko DWCBI241.S.AU (English - 46 pages)
Here's the information relevant to your problem.
The Care and cleaning section has this information on clearing the drainage pump.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks for your prompt reply. Sorry, the error code would be F10 and model number is DWCB1241.S.AU
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Rashedul Alam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 31
Her zaman: 447
